Topic:   VBA Interaction
By: GuestPosted on: Aug 4 2021 at 02:38:38 PM
Can you interact with this software using VBA scripts? For example, I would like to scan a work order and have the milling program load and send automatically.
By: MattewPosted on: Aug 6 2021 at 02:42:39 AM
Many years ago on Windows 95 version of EasyDnc we used to do something with barcode scanner. We don't do it now though so I don't know whether it works on new versions of anything.
When you select 'send to cnc' from the menu a window appears where you select the file you want to send. That window looks different on different versions of Windows. I wonder if it might still be possible to click the cursor into the file select text box and then, with the barcode scanner, to scan the file name into that box.
Topic:- VBA Interaction
