Topic: Siemens, Okuma and Gildemeister can Receive but can't send
By: Guest | Posted on: Dec 15 2021 at 01:40:57 PM | Hello,
I've used your software to connect from notebook to CNC machines with usb-adapter rs232 25 pin.
I've estabilished connection with FANUC for 4 machines, but from the others I can receive only.
The CNC are:
GMT siemens 810t
Gildemeister
Okuma
Thank you in advance. | |
By: Guest | Posted on: Dec 15 2021 at 06:43:27 AM | sending to okuma make sure the program header is arranged like this
The dollar symbol and the percent either side of your program name.
$FILENAME.MIN%
etc
etc
By: Guest | Posted on: Dec 15 2021 at 06:47:50 AM | For the okuma the program you received from the okuma may not look the same as mentioned above. You may need to edit it to make sure it's the same as above.
For the siemens 810. Send ONE program from the machine to the computer. Look carefully at the top of the data that was sent from the machine. Programs and Sub programs are slightly different.
Make sure that the program you're sending back to the machine is arranged the same way
For the gildermeister. Sorry. I can't help. Don't have one of those in my shop. | |
By: Guest | Posted on: Dec 15 2021 at 06:49:43 AM | Forgot to say that siemens programs with numbers above 8000 (or maybe 9000. can't remember) are built-in canned cycles and can't be sent in. so make sure the program number is below that. | |
By: Guest | Posted on: Dec 16 2021 at 05:12:39 AM | Hello,
I've changed machine in the DNC dropdown-menu in top right window position
(FROM OKUMA to FANUC) and now It works!
Tomorrow I will try Siemens and GIldemeister.
By: Guest | Posted on: Dec 21 2021 at 12:22:38 AM | Good morning,
I am trying to send Program to Siemens but It doesn’t work.
I receive with this config:
Baud: 9600
7 Bit, Even Parity
Stop bit: 2
Flow control: RTS
What settings I should configure in:
End of block ?
TX timeout ?
Block Delay ?
Is auto mode correct?
By: Guest | Posted on: Feb 5 2022 at 08:19:35 AM | Isn't there a sinumerik mode? | |
