in the setup cnc you can set up your default data folder location. So when I select a file to send to cnc it brings me to my default(customer)data folder. I then scroll thru that folder to a (specific customer) folder and select a file to send. I send it and have no problems, but when I select to send another file to cnc it does not default back to the (specific customer)last place I was at and have to scroll back thru the default (customer) folder. Is there some way to get back where I was without starting from the beginning?
By: Jon
Posted on: Jan 16 2020 at 01:56:03 PM
If there is a solution I would like it, but currently we are dragging and dropping from windows.
Posted on: Jan 19 2020 at 06:27:31 AM
Even if it did remember the last folder Dragging/dropping from Windows is the best way to do it anyway..
Just open your customer folder in windows and leave it open - then just drag any file and drop it onto the machine icon - or into the textbox. Works even better if you have a touch enabled display. I've got a Windows tablet.
