Hello I have install remo to our machine with fanuc oi-mc control threw rs232 cable following instructions on your website when starting drip feed following error is showed: (114 format error in macro)Can you help us please? identical G code runs without a problem on similar dnc software on the same machine. We would realy like to make remo work as it have pause option...
Posted on: Oct 8 2020 at 02:50:28 AM
When does the alarm occur? At the very start of the program ie on the very first line? Or does the machine manage to run some part way through the program before giving the alarm?
By: Jade
Posted on: Oct 8 2020 at 03:05:08 AM
If it starts as soon as you start then you need to look at the way the CNC program is formatted. Make sure the program number starts with O (Capital Letter o not a zero)
If it manages to machine a few lines in before the alarm then look at the syntax. Some If/THEN syntax is not identical across all Oi/OM machines.
