whenever i send a file to the cnc, i get an alarm. we have tried various nc codes and all arrive at the same result, what can be the possible cause.
Posted on: Feb 26 2019 at 01:38:56 AM
What alarm is it?
If it's alarm 087 then you need to do one or more of the following
1. Enable Flow Control (In the DNC software. XOn/Xoff)
2. If #1 doesn't work then in the DNC setup increase the 'Block Delay' (Bigger number)
3. Of #2 doesn't work - switch CNC and DNC to a lower baud rate.
Flow control should be enabled anyway but if you do switch to a lower baud rate you can possibly decrease the block delay (smaller number)
