Topic: Drip feed traub
By: PlshelpPosted on: Dec 29 2020 at 11:50:00 AM
Is this possible to traub mx8 work on drip feed? Transfer from pc to machine works well but there is not enough memory.
By: GuestPosted on: Jan 2 2021 at 05:47:14 AM
On something like a Fanuc there's a switch or dial on the panel to select memory or tape mode. The memory mode is for running programs out of memory. The Tape mode is for running programs from tape. In this case easyDNC simulates the standard tape reader.
On a fanuc you'd select Tape mode and then hit the Cycle Start button. At this point the machine won't do anything. It's waiting for the tape to start rolling. You'd then go to eacydnc, select the program and press Send.
On your Traub you need to be looking for something similar. Some way to press Cycle Start without first selecting a program.
