Topic: DNC connect okuma osp100
By: GuestPosted on: Jun 12 2019 at 01:53:30 AM
I wanted to try use easydnc for data transfer to okuma by TCP/IP
But I didn't do it?
Can you share settings for okuma?
By: SupportPosted on: Jun 13 2019 at 04:45:25 AM
First I'd suggest making sure it works locally - For example take a laptop and connect directly to the RS232 port on the Okuma.
When you have all those settings figured out you can then step back and connect over TCP/IP using the same settings (except using IP address instead of COMPort)
When you say TCP/IP I assume you mean you're connecting to an RS232 port server/device on your network and not the CNC's own RJ45/Ethernet port?
