Hi
using this with colchester 4000L lathe Fanuc OT,can send program from lathe but not from PC get 087 alarm. Baud rate is set to 2400 at PC and lathe
Posted on: Jan 13 2022 at 10:16:20 AM
Hello. We did this via email. Just commenting here in case other people have the same question
Fanuc 087 alarm is usually a buffer overflow. In your case though it was caused because the CNC did not recognize the start of the file allowing the buffer to overflow while waiting for the start.
Before sending to the cnc you need to delete the top line with the |&HE: Leave just the percent symbol. Like this.
:0036
N10 etc
etc
But that may not work. If it doesn't then make one more change. Change the :0036 to an upper case letter O Like this.
O0036
etc
After do the above you started getting a PS002 error. This is block parity. in the CNC you need to disable TV Check.
You did the above and, if I'm not mistaken, everything is working now.
Posted on: Aug 4 2023 at 10:13:26 AM
I am facing same problem on my Mill, I just don't understand that when I run same program again without any changes than it works as good. So is there any upgrade required or what?
Posted on: Aug 11 2023 at 06:10:19 AM
Sorry. Not sure I understand.
You send the program once and you get the 087 alarm. You cancel that and send again and the second time it works?
Posted on: May 20 2026 at 06:35:36 AM
I know this is an old post but I had this same problem. The fix is simple.
My machine program didn't start with a % percent character but it ended with one. It's the percent character that wakes up the machine that data is coming. So the first time I sent the program the machine didn't se it. Just a load of data. At the end of the program it ended with the % and that wakes up the machine. I sent the program again and it accepted it.
Simple fix was to put a % at the start of the program - although for drip feeding not all machines need that % at the start but it doesn't harm
