Topic: 003 p/s handshake alarm on fanuc om
By: DanielPosted on: Mar 14 2020 at 02:32:15 PM
getting a handshake alarm every time i run a program thats longer than about 2 mintues, any ideas whats going on?
By: GuestPosted on: Mar 16 2020 at 07:53:09 AM
Check that flow control is enabled in dnc setup. Usually XOn/XOff
Try increasing 'Block Delay'. Put it up to the biggest number. This is likely to make everything work much slower but see if you can run for longer than 2 minutes. Then reduce the block delay a few steps.
What baud rate do you have?
