Using a demo version to transfere file on a fanuc OM control. Works great from CNC to PC but I lose the program name going from PC to CNC. It's in parenthesis and is also adding an EOB character to each line of the program.
Posted on: Jun 2 2011 at 10:24:46 PM
Check in easydnc setup. Is there an option to make it send or ignore text in parenthesis?
Also in easydnc setup, check the option block end. That tells it what to send at the emd of each block.
Posted on: Jun 3 2011 at 01:50:16 PM
Thank you for the help. Forgot to add a % to the beginning of the program and my not paying attention to one of the boxes in the set up. Working great now.
