By: Aerotech-NCPosted on: Aug 15 2012 at 04:17:34 PM
Could you please inform me if your easy DNC software will support the above controller ? we are looking to connect a PC and drip feed / upload and download files from and to PC to Controller
By: Guest Posted on: Aug 15 2012 at 07:20:48 PM
I coud be wrong. Usually am :( but I kinda think that the hartrol fanuc Ai100 is just a standard Fanuc Oi with some eye candy.
You should be able to transfer files to/from CNC memory and assuming it is basically the same as the Oi then yes, it can be drip fed. On the control select Auto (DNC) mode and press Cycle Start. Then go to easyDnc and press the send button.
By: tharuka deshanPosted on: Oct 8 2015 at 02:44:43 PM
I learned to work
By: rameshPosted on: Mar 18 2017 at 10:33:05 AM
By: GuestPosted on: Mar 18 2017 at 11:32:08 AM
Manual for Fanuc? Sorry. You'll need to ask your machine rep.
Manual for Dnc Software?
