Topic:   Haas buffer overflow
By: DavePosted on: Nov 17 2017 at 11:20:49 PM
Hi i just got a 1996 haas vf6
Does anyone know the remo dnc settings please i thought they were ok but the computer tries to dump the massive program with no pauses so i get overflow
What is the best thing to do
Please help
By: DavePosted on: Nov 17 2017 at 11:21:57 PM
And do ì need to alter anything on tge haas controller if so what and where
By: GuestPosted on: Nov 18 2017 at 09:59:17 PM
If the program goes in to the cnc but goes in too fast causing buffer overflow then i think we can assume baud rate etc are all correct.
Make sure flow control is enabled. Thats xon/xoff in the cnc parameters. Also make sure that xonxoff is enabled in the dnc software.
If it still overflows maybe consider lowering the baud rate. (Set the same baud rate in the cnc and in the dnc software).
Or increase the block delay in the dnc software setup.
Does your haas have an xmodem option? If it does then try that.
Topic:- Haas buffer overflow
