Topic:   Fanuc Control System II
By: GuestPosted on: Jul 10 2018 at 12:28:50 PM
Does your software support this controller?
By: GuestPosted on: Jul 12 2018 at 09:49:35 AM
Not sure what this is. Do you mean something like the Hardinge/Fanuc Control System II (Hardinge II with FDanuc OM-D control?) should be n o problem
All fanuc machines should be supported. They're pretty basic machines. Download the software. Go to setup and set it to Mode = 'Fanuc' or 'Auto'. Set the baud rate, databits etc as per the CNC and it should work on any fanuc.
For cable diagrams and parameters etc
Try this page [Fanuc]
Topic:- Fanuc Control System II
