Topic:   Does your software need "Run As Administrator"?
By: BelugaPosted on: Mar 30 2019 at 09:15:32 AM
Our computers are managed by computer department - I can't run anything "As Administrator".
Does your software work for normal non-admin users?
By: SupportPosted on: Mar 30 2019 at 12:00:00 AM
Our software does NOT require "Run as Administrator". It is fully compliant with security and UAC (User Access Control) in the very latest versions of MS Windows so can be used by normal users without admin credentials.
However, your computer department may prevent you "installing" software. In this case your computer department would install for you but then, after installation, no special permission is required and you can use the software without admin credentials.
Topic:- Does your software need "Run As Administrator"?
